GEN light?? TACH bouncing all over?? and trans??
Old May 30, 2007 | 12:58 PM
vzdude's Avatar
DTR's 'Go to Guy'
Feel the relay ( or better yet, unhook them ) on the pass. side fender when it happens. You will feel them click if they are turning on. Other than that, the diodes may be going out on the alt causing dome funky voltage to the computer as well. Take it in to a reputable shop and have them test it. You can test yourself IIRC with a DVOM and look for AC voltage from the case to the big red wire on the back of the alt. Again IIRC!
Old May 30, 2007 | 01:00 PM
vzdude's Avatar
DTR's 'Go to Guy'
BTW, the relay actually is a solenoid. Looks like a small remote solenoid on a lawn mower type. IIRC there is 2.
Old May 30, 2007 | 02:33 PM
Racing_Joe66's Avatar
i am going to take the alt off my other truck as i had it tested and it works fine and see what that does. i will check the relays for the heater grids. and c what that does.
Old May 30, 2007 | 04:07 PM
just took the alt in and it checked out good. i took the sensor off the dampner and the red wire on it had a slit in it and u could see the wires. and also the red wire between that slit and hte sensor it was pinched pretty good. the slit was probably about an inch to inch and a half up from the sensor. hopefully this was my problem.
Old Jun 5, 2007 | 02:36 PM
changed out the ESS and so far the tach and OD hasn't acted up.
but there is still a flicker in the whole lighting system at all times. they will all flicker everytime u hit the brake pedal it never fails.
so there must be something with the brake wiring. any help???
thanks
Old Jun 6, 2007 | 01:42 PM
any ideas on the whole lightin system flickering???? also i have my scan tool hooked up to this truck n the volts gauge goes all over the place. 12.6-15.8 it just jumps all over n so does the TPS one only when i am cruising at the same speed. also i have noticed in this truck that at idle the TPS sits at 6. my other 97 sits at 23 at idle.
Astro
Jul 31, 2009 11:06 AM
Lundee
Feb 17, 2008 11:05 PM
kelownadiesel
Jun 1, 2006 10:58 AM
bowhunter
Jun 28, 2005 08:51 AM
bigfoot
Aug 14, 2004 02:22 PM
