Fuse for dimmer switch
Just installed my gauge cluster and I cannot find which fuse is for the dimmer switch/headlights. Do I tap it into the fuse box or do I splice it into a wire run??? if so which wire. I read a large blue wire but i dont see a large blue wire
Use a test light on the wires going/leaving the dimmer selector and see which one responds to the switch. Depending on what gauges you have (Autometer Cobalts use LED lights) this might not be enough to dim the lights to match you panel lights. You can use a resistor on each gauge to make them match your panel. Start out with a 1K ohm 1/4 watt resistor (real cheap at Radio Shack) on each gauge and see if it is what you want. If it dont respond how you like go up or down on the resistance to your preferance.
Or you can buy a dimmer from Autometer. The model # is 9114.
its the ISSPRO gauges, so just regular lights. I did a search and someone said to stick it on the illumanant fuse, but they stay on all the time. I think I am just going to get a **** variable resistor and install my own switch.
I powered my gauges off of this fuse block by running the wires from the gauges into the back of the fuse panel (by removing the kick panel below the steering wheel) and then by tapping into the instrument gauges using an "add a fuse" that I purchased at Pep Boys. The A-Pillar gauges dim with the main instrument lights. Hope this helps.
John (DH)
Here's a pic of where to tap into on the back of the headlight switch on a 04. This is from a guy on another forum. I can't access it right now for some reason. I just had the pic saved. I need to double check that it's the diimer wire and will dim, and not just stay bright. I'll keep trying to get on the other forum.
http://community.webshots.com/photo/...15904532clGJIA
Originally Posted by Herrin821
Also, I went past Herrin IL today. Is that where you get your screen name from.
Yep...City of Herrin badge #821....You runnin down 57?? Musta been deer hunting?? I let 3 does walk by this afternoon
Orange wire/brown tracer....left side, bottom (as you look at the bck of the switch)
jesse123
Jul 8, 2012 09:04 PM
Charlie8301
18
Jul 29, 2006 02:30 PM
Vontin111
Aug 15, 2005 06:27 PM
ckennedy
Nov 15, 2004 06:54 PM
