Fuel pressure/Quad Commander
Old Aug 27, 2007 | 01:47 PM
shortbed rv's Avatar
My Quad Commander has started to read zero fuel pressure at idle. The rail pressure still reads 7000 at idle. If I travel at 65mph the pressure rises to 7 PSI but if I let up the pressure will drop to Zero. I changed the fuel filter but that did not help. The truck starts and runs good, if I did not have the guage I would not know there is a problem. I checked volts at the sending unit and I have 1.8 volts at idle.
Is this the fuel pump or a guage problem?
Thanks guys for the help this is really worrying me.
Old Aug 27, 2007 | 10:26 PM
bighornrmk's Avatar
It's probably the fuel preasure sending unit. I'm on my fourth one in about 10 months. Call Quadzilla and tell them the problem. They will send you a new one.
Old Aug 27, 2007 | 11:51 PM
Thanks bighorn
I called and Quad is sending a new sending unit.
Old Aug 28, 2007 | 03:16 PM
received and replaced the sending unit. Works fine.
Ordered one day and received the next day. You can not beat Quad service!!!!
Old Nov 25, 2007 | 08:52 AM
lxlaw's Avatar
They made you pay for it?
Old Nov 30, 2007 | 11:21 PM
Hi lxlaw
Good news and bad news. Good news is I only paid for shipping back but they held my credit card number until they received the old unit ( ok with me).
Bad news the (new)three month old unit is not working.
Old Dec 1, 2007 | 07:42 AM
lxlaw's Avatar
****, LOL, i just got mine in yesterday. I am curious if they could use the stock dodge oil pressure sending unit or another one that may be better. I noticed the one they sent me was an oil sending unit, so obviously it is just a generic sender. I wonder what is the ohm range of the unit they are sending us? I wonder what's the ohm range of the stock dodge oil sending unit. I believe the stock dodge sending unit also grounds through the plug, so if you have a fass with rubber lines, then you wouldn't have to worry about grounding the sending unit externally.
Old Dec 1, 2007 | 08:50 AM
Megaramasaur's Avatar
If someone finds a better sender let me know, Quadzilla has replaced mine 3 times, and this one is all over the place too. My manual pressure guage will read steady on top of the filter canister, I've also changed pumps as well, so I know it's not the pump.
Old Dec 1, 2007 | 11:18 AM
Krob's Avatar
I am on my 4th unit they are in the process of getting a newer heavy duty sensor/sending unit but it may take some time.
Old Dec 1, 2007 | 11:21 AM
lxlaw's Avatar
I know someone on here is electronically smart. Find out what the ohm range of the sensor they are using and see if there is a factory OEM sensor like from dodge, ford, chevy, etc.. that is in the similar ohm range. I know they have some adjustment on the commander for making it exact.
josterbauer
23
Nov 25, 2007 10:44 AM
moparman13045
Jul 5, 2007 09:44 PM
riversidediesel
Feb 9, 2007 06:31 AM
jaredb900rr
38
Nov 6, 2006 12:09 PM
