fuel line air leak-somewhere
Old Jul 20, 2008 | 11:52 AM
clive's Avatar
Unhappy fuel line air leak-somewhere
another non starting truck,seem to have the same air leak in fuel system,i have needed to slacken open the first injector to get truck started,this is ater installing a mechanical fuel pump,had some screws missing where the injector pump was,got those back in and tight,below that on the fuel line theres a brass plug,maybe a filter in there,dont know,now could i have a leak in the line at the tank,im getting a air block in there somewhere,been good for a month,now happened again,any ideas.
Old Jul 20, 2008 | 12:12 PM
What year truck?
Old Jul 24, 2008 | 02:24 PM
clive's Avatar
1993 with cummins,if i try some snoop or soapy water to detect a leak should i have the truck running or should i pre spray it then try looking for the leak while i crank it over
Old Jul 24, 2008 | 02:29 PM
1-2-3's Avatar
Just a plain ole guy
Soap probably won't do it. Look for an oily spot on the fuel supply and return lines. Have you changed the fuel filter lately, or opened the fuel system up anywhere? I'd inspect that spot first if you did.
Old Jul 24, 2008 | 03:19 PM
clive's Avatar
i put in new mech, fuel pump,had bolts missing in injector pump,theryr all tight now,but if i have to slacken off an injector to get the fuel moving ,would my leak be somewhere up front of the fuel filter ,could the diafram in the injectr pump be toast,maybe distorted or damaged, ive started my truck without problem every day for the last week now,seems ok,still get killer milage
Old Jul 24, 2008 | 05:51 PM
The best way to find a fuel leak is to blow a little air pressure into the fuel tank and look for leaks in the lines. The lines are normally under suction, and a little pressure in the tank turns those invisible air leaks into drips of fuel.
Old Jul 25, 2008 | 02:03 PM
clive's Avatar
k,thanks WD,i'll try that angle next
Old Jul 26, 2008 | 12:21 PM
clive's Avatar
on each fuel line at the nut where there is the compression fitting,there is a sleeve around each line where the nut slides over and then threads onto its fitting, there is no sleeve on the fuel line on the top side of my mech, fuel pump, this is the nut i have had to loosen periodically to get the fuel movin,i suppose theres enough slack in there to cause a leak, does that sound possible,it would be the last place to check,ive looked over the entire fuel line system,no leaks visible
Old Jul 26, 2008 | 06:27 PM
It sounds to me like you have a leak between the lift pump and the tank. Concentrate on those lines.
prlsnpsdodge
Aug 17, 2012 04:46 PM
GCSS
Dec 15, 2009 06:12 PM
CTD2001
13
Jan 21, 2009 06:18 PM
PistolWhipt
Aug 8, 2005 09:18 AM
mr T
Apr 8, 2005 04:32 PM
