Oil leak from somewhere...
Old Aug 17, 2012 | 01:27 PM
prlsnpsdodge's Avatar
I dont climb underneath my truck every day, but when i was under it last week doing an oil change I noticed what appeared to be a small oil leak coming from the drain plug... Upon closer inspection. i've got oil definitely coming from either the plug, or the back of the pan where it attaches. I've replaced oil pans before on other vehicles, how difficult is it on these trucks??? ANything I should know about up front??
Old Aug 17, 2012 | 03:31 PM
Hintonc393's Avatar
Motors gotta be lifted up to get the pan off.
Old Aug 17, 2012 | 04:46 PM
steelblitzkrieg's Avatar
DTR Detective
Are you 100% sure it's oil?
If you haven't experienced it before, the rubber coupling on the coolant line near the turbo is notorious for leaking and it can make you swear it's an oil leak.
The first time it happened it ran down the back of the oil pan. The last time it happened on mine I thought it was the front crank seal because I couldn't find a leak from the coolant coupling, it would only leak after the block cooled down.
reedy175
Jul 27, 2010 07:39 PM
CTD2001
13
Jan 21, 2009 06:18 PM
clive
Jul 26, 2008 06:27 PM
GR40RCapri
Oct 9, 2006 08:13 AM
PistolWhipt
Aug 8, 2005 09:18 AM
