Is there a port somewhere for another oil-drain back?
Old Oct 8, 2006 | 10:54 PM
GR40RCapri's Avatar
it thought i saw someone mention something about a pipe plug on the lower portion of the block near the filter adapter, but i can't seem to see anything..
i'm working on installing the bypass filter..
any help is appreciated!!
thanks.
J
Old Oct 8, 2006 | 11:39 PM
rockwithjason's Avatar
There is a press in plug on the rearward section of the block on the passenger side. It's on the same elevation as the oil dipstick tube. When I installed my bypass filter I drilled and tapped the valve cover for my return, works great.
Old Oct 9, 2006 | 01:00 AM
Jambbii's Avatar
We dont have them on our 12vs
Old Oct 9, 2006 | 05:59 AM
GR40RCapri's Avatar
so how do most guys go about returning the oil to the pan with a twin setup? just make a new drain pipe with a Y in it?
thanks guys!
i think i might return the oil to the filler neck so i can see when the filter needs to be changed by the degrade in flow..
J
Old Oct 9, 2006 | 08:13 AM
JKM's Avatar
JKM
Most guys with twins weld a port into the oil pan.
reedy175
Jul 27, 2010 07:39 PM
GCSS
Dec 15, 2009 06:12 PM
Dodgezilla
16
Feb 19, 2009 06:29 PM
QWKRTNU
Sep 26, 2006 10:22 PM
