Is there a port somewhere for another oil-drain back?
it thought i saw someone mention something about a pipe plug on the lower portion of the block near the filter adapter, but i can't seem to see anything..
i'm working on installing the bypass filter.. any help is appreciated!! thanks. J |
There is a press in plug on the rearward section of the block on the passenger side. It's on the same elevation as the oil dipstick tube. When I installed my bypass filter I drilled and tapped the valve cover for my return, works great.
We dont have them on our 12vs:(
so how do most guys go about returning the oil to the pan with a twin setup? just make a new drain pipe with a Y in it?
thanks guys! i think i might return the oil to the filler neck so i can see when the filter needs to be changed by the degrade in flow.. J |
Most guys with twins weld a port into the oil pan.
