Fuel leak
Old Nov 4, 2003 | 09:16 PM
Fishinghaoliboy's Avatar
Fuel leak
I got home today and my truck has a diesel leak at the bottom of the fuel filter. It seems to be coming from the drain fitting on the bottom of the filter. A spontaneous leak. Changed the filter about 2 months ago with no leaks but have one now. Tried to drain a little fuel by pushing up on the water drain thinking it might have something in it. I have not touched anything for about 2 months. Any ideas about the spontaneous leak?
Old Nov 4, 2003 | 09:31 PM
phox_mulder's Avatar
Re:Fuel leak
[quote author=Fishinghaoliboy link=board=13;threadid=22017;start=0#msg205809 date=1068002174]
[/quote]
Try exercising the drain valve.
They have been know to stick open a little, or vibrate open a bit.
phox
Old Nov 5, 2003 | 05:42 AM
Smokee's Avatar
Re:Fuel leak
I suggest that the leak might be from one of the rubber fuel lines, and appear to be from the filter.
Something to check.
Old Nov 17, 2003 | 04:33 PM
Re:Fuel leak
Just to finish off the answer to my fuel leak at the fuel filter I bought a new sensor/drain from Dodge at the cost of $50.00 ??? Removed filter and installed new valve/sensor and the leak was worse. Did that about 3 times getting cut by the clamps on the boost hose and then bought a new filter and changed that, (the old one was 3 month's old, a NAPA filter), the leak was the threaded portion at the bottom of the filter. So now have 2 drain valves and a new filter (also from NAPA) and no leaks.
Denny
Jaybug
Dec 24, 2013 11:23 PM
ZPOD
18
Sep 23, 2010 10:37 AM
superdiesel9
Oct 25, 2009 07:56 PM
donhov
26
Jan 6, 2006 07:29 PM
Lightman
16
Jan 21, 2004 10:46 PM
