fuel leak
Old Oct 18, 2006 | 08:49 PM
JW3's Avatar
JW3
fuel leak
newsflash, Plumber cant find where fluid is coming out of fuel line.(ha ha)All my connections are good and not leaking, but by looking under the truck I can see where the fuel is dripping from somewhere around the top of the firewll. Anyone have any suggestions??
Old Oct 19, 2006 | 10:03 AM
infidel's Avatar
Leaking water drain on the filter bottom?
Old Oct 21, 2006 | 03:51 PM
JW3's Avatar
JW3
nice try sir
afraid not it apprears to be coming form somewhere along the firewll. any more suggestions??
Old Oct 21, 2006 | 06:42 PM
REF>Lancer's Avatar
I'd guess that if your fuel pressure gauge uses a capilary line than that is leaking where if goes through the firewall.
Or,have you checked to see if #5 or 6 injector lines are leaking? since you just had a vp44 installed...they say its a bad idea to use your hand to check this on a running engine...lotsa pressure
Old Oct 21, 2006 | 07:09 PM
Kevin B's Avatar
Dang REF, ya beat me to that one. I noticed in his sig. he has a F.P. gauge and thought the same thing .
Old Oct 22, 2006 | 10:07 PM
JW3's Avatar
JW3
good idea,but wrong answer
My fuel guage has an electric isolator no fuel is going into the cab. anyone else care for a guess, or hypothesis.
Old Oct 23, 2006 | 11:34 AM
Tazman's Avatar
JW3,
There's a return line and banjo at the back of the block.
Check it out.
Jaybug
Dec 24, 2013 11:23 PM
ZPOD
18
Sep 23, 2010 10:37 AM
superdiesel9
Oct 25, 2009 07:56 PM
donhov
26
Jan 6, 2006 07:29 PM
Lightman
16
Jan 21, 2004 10:46 PM
