Fuel Gelled for the 2nd time
It probably won't hurt a little just this once but alky attracts water which makes rust on the very close tolerances of the steel parts in the injector pump on mine and high pressure pump on yours.
Isn't your motor still under warranty?
Hey fellows, chill out. We are here to help, not belittle. I,ve been running diesels of my own since 1981. The only time I had a fuel problem was when it got down to zero degrees F. I think what you are seeing isn't a fuel gelling problem. Number two winterized diesel should run in PA. just fine until it gets below the single didgits.
Check these sites out to see if they will help you.
http://dodgeram.org/tech/dsl/mt_2_fe...l_sys_comp.htm
http://dodgeram.org/tech/dsl/mt_2_fe...leshooting.htm
On the 2nd one scroll down to Hard Starts
MANY THANKS TO EVERYONE WHO OFFERED ADVISE AND TIPS. Truck is running now after it sat all night in the barn. Definitely was gelled fuel.
Not that it will do anything but I think I am going to call the fuel company and ask them about treating their fuel. I will also be getting fuel somewhere else. Thanks, again.........
