Fuel canister leak!!!!
Old Dec 17, 2006 | 01:08 PM
dbrown509's Avatar
Hi All,
New here. Has anyone had problem with drainvalve on fuel canister leaking. When I open it dumps as it should. When I close it it still trickles out. When it is put under pressure it seems to leak all over on the drain valve. I looked at o-rings everything ok. Can you just change the drain valve or do you have to get a new canister complete. Is this a dealer only item? Its Sunday and all dealers closed. I have to make a run to Cal. in a little bit so just wanted to see if anyone had any ideas. Thanks 99 Dodge 2500
Old Dec 17, 2006 | 01:26 PM
dieselmech01's Avatar
its probably got dirt os some debris keepin it from sealing
Old Dec 17, 2006 | 07:20 PM
kawi600's Avatar
Are you losing prime, especially after sitting overnight? I think mine is leaking air since it was dribbling fuel a bit too.
Im going to go price a new WIF / drain assy from cummins this week I think.
Old Dec 17, 2006 | 11:50 PM
Dr. Evil's Avatar
What year of truck are you talking about? We need specific info about your truck....
Old Dec 18, 2006 | 04:30 PM
dbrown509's Avatar
Sorry put it at bottom of post. 1999 Dodge 2500 2wd no ad ons just plain jane work truck. Thanks
dodge_24
Oct 1, 2009 05:33 PM
Spooler
22
May 6, 2009 06:50 AM
dodgerdog
Aug 21, 2008 10:25 PM
dodgediesel4x4
Sep 4, 2005 03:17 PM
steveb
Aug 20, 2004 12:48 AM
