Front axle Universal issues
Old Nov 21, 2009 | 04:05 PM
schoust's Avatar
Well Guy's here we go again! Every time I turn around I have another problem with this truck! All I can say is it's a good darn thing I'm a mechanic Lol! Ok Guy's I had a front caliper lock up on my today and it was about that time to change the pads anyway and do a complete inspection of the front end etc. I was doing my regular thing and came across the bad Universal on the driver side. Anyway I have not had this apart to do anything yet and need to get this wrapped up fairly quick so I can go to work on Monday. I am all ears Lol Thanks in advance.....
Old Nov 21, 2009 | 07:29 PM
akrammit's Avatar
Just pull the caliper, bearing and axle shaft. Replace the u-joint as you do with any other one and reverse. Getting the bearing out can be a pain sometimes. There is an ok trick to get them out. Use a punch or something similar and place it on the bolt heads once loosened up. Turn the wheel till the other end is against the axle then use the force fo the steering to push them out. You'll have to do this a few times going back and forth on each side of the bearing.
Old Nov 21, 2009 | 07:52 PM
Brian08Q35004x4's Avatar
From: This Nazi state of California 2nd home Gilbert AZ under God
Using a press is the easiest way of changing the front axle universal. It slides right out after you pull the caliper and pull the rotor. pull the spindle hub and slide it out. Make sure to spray every thing with a good penetrating oil first after removing the caliper. For the rotor and spindle a 14$ puller from Harbor freight is the easiest way without doing any harm.
Old Nov 21, 2009 | 08:27 PM
schoust's Avatar
Brian do you have a model number on the puller you used? Anyone have a step by step? Never done this before and could definetly use some help....
Old Nov 24, 2009 | 05:50 PM
cminzey's Avatar
don't need a puller
You don't need a puller use the power steering to push the rotor off the spindle if you need to email direct
chuck
cminzey@aol.com
Old Nov 27, 2009 | 09:30 PM
midwestdually's Avatar
Is there a metal spacer between the ujoint and the bearing assembly?
BC847
Jul 30, 2013 08:48 PM
KWKING
Nov 29, 2012 09:42 PM
ollie32
Aug 8, 2007 11:05 PM
Nav
Jul 21, 2006 09:19 AM
redram
Dec 1, 2004 10:21 PM
