four wheel drive not working
Old Dec 27, 2007 | 08:11 PM
izzwardo's Avatar
Went out to run some errands while it was snowing, put it in four wheel drive and nothing. The light does not even come on. Just had transmission rebuilt a week ago. Any ideas?
1995 Dodge diesel, Automatic, AFE cold air intake, HD transmission, HD torque converter, Fuel plate,
Old Dec 27, 2007 | 08:17 PM
cm979's Avatar
Did you check the pig tales on the axel or the transfer case just a thought.
Old Dec 27, 2007 | 08:19 PM
izzwardo's Avatar
What do they look like?
Old Dec 28, 2007 | 12:10 AM
camelracer's Avatar
There's a vacuum switch on top of the transfer case that controls the front axle disconnect. Check to see if the tranny shop hooked the vacuum lines back up correctly or you might have a vacuum leak.
Old Dec 28, 2007 | 12:35 AM
izzwardo's Avatar
I will check that! Thank you very much!
Old Dec 28, 2007 | 01:50 AM
Big Smoky's Avatar
You probably have a vacuum problem. Posilock makes a cable that you can put in place of all that vacuum stuff to where you can lock and unlock the front end manually from in the cab so you don't have to worry about if it's locked in or not. I had it on my old 95 and loved it.
Old Dec 28, 2007 | 02:17 AM
12 valver's Avatar
the vacuum lines probably worn through under the transfer case. A little jb weld fixed it for me on the side of the road.
Old Dec 28, 2007 | 06:02 AM
strokerace's Avatar
There is a posi lock kit they sell on ebay for around $160, when mine quits thats what I plan on fixing it with. I would check the vaccum lines first though to make sure everything is hooked up. Good Luck
Old Dec 28, 2007 | 11:50 AM
izzwardo's Avatar
Thumbs up
Hey everybody thanks for all the input! This site is awesome! Turns out the transmission shop got the vacuum line backwards. What a relief. Just got it fixed this morning and 4WD works perfectly!
freshmeat
May 26, 2010 07:35 AM
doug60
Oct 17, 2005 11:51 AM
tjohnson
Feb 14, 2005 12:17 PM
Garz
Feb 18, 2003 10:07 PM
