front wheel squeeks when in four wheel drive
Old May 24, 2010 | 06:40 PM
freshmeat's Avatar
On my dads 03 cummins, it will squeek up by the drivers side front wheel when in four wheel drive. It wont do it in two wheel drive, is there a bearing going out or something. It only does it when the wheel starts turning. Thanks
Oh, we did check the u joint and it seems fine, I wonder if the bearing is going out. It will only do it in four wheel drive.
Old May 24, 2010 | 09:26 PM
rebal's Avatar
sound like a dry u joint jack it up and push in and pull out on the wheel see if you have movement in the bearing
Old May 25, 2010 | 10:49 AM
Stamey's Avatar
Likely a bad axle u-joint, especially since they are not greaseable.
Chrsi
Old May 25, 2010 | 12:49 PM
Hodge's Avatar
x3, even though the u-joints turn all the time, they will show their wear when they are loaded up, as is the case when in 4WD.
Old May 25, 2010 | 02:45 PM
RowJ's Avatar
They don't all turn ...all the time. Only after mid 2002.
The CAD (Axle Disconnect) could explain the squeek. Need to engage 4x4 every once in a while to keep everything lubed up!
I had a rotational squeek after getting lazy about using 4x4 regularly. Engaged it once a day for a week and the squeek went away!
RJ
Old May 25, 2010 | 08:53 PM
Hodge's Avatar
RJ
With or without the CAD, the axle u-joints turn all the time, unless you have installed a locking hub kit.
Old May 25, 2010 | 09:51 PM
freshmeat's Avatar
Thanks for the info guys, I will try to take the u joint off this weekend to see if its bad.
Old May 26, 2010 | 07:35 AM
RowJ's Avatar
Originally Posted by Hodge
With or without the CAD, the axle u-joints turn all the time.........
Yup! Sorry, did not read all the posts. Thought your post was about the front drive shaft u-joint.
RJ
MaineRam
Jan 3, 2013 08:20 PM
Journier
Dec 2, 2009 09:14 AM
tjohnson
Feb 14, 2005 12:17 PM
Garz
Feb 18, 2003 10:07 PM
