exhuast manifold
Old Sep 6, 2006 | 11:40 PM
West Coast's Avatar
exhuast manifold
I am going to replace my exhaust manifold on my 94 CTD. Is there any tricks or things I need to look out for when swapping out the old with the new 3pc from scheiddiesel??
Does the turbo have to come off?
Thanks....
Dave
Old Sep 7, 2006 | 03:10 AM
Rauschbo's Avatar
The turbo bolts up to the exhaust manifold, so......
I put the ATS on my truck, perhaps they are similar enough that a few tips may help: When assembling the pieces, heat the "outers" and freeze the "inners", and assemble with anti-seize; Use the old manifold as a pattern (bolt one to the other), this gets the final configuration VERY close, so when you are actually putting in on the engine, it's a drop-in part....
Old Sep 7, 2006 | 12:31 PM
JD730's Avatar
Pretty much a nut and bolt job. Putting the manifold together might try your patience a little.
No, but it will be easier to do it with it out of there.
I don't know if the 24valves are different, but the one I did I had to freeze the outers and heat the center. Use anti-seize, we used the old manifold to line everything up too, but I had to use my 'adjusting tool' (hammer and a long block of wood ) to get it to line part of it up on the engine.
Old Sep 8, 2006 | 05:47 AM
Rauschbo's Avatar
- sorry, I meant heat the components that go on the OUTSIDE, freeze those that go on the INSIDE....
Old Sep 8, 2006 | 06:46 AM
Geico266's Avatar
Start spraying PB blaster on it the night before you take it off.
Old Sep 8, 2006 | 12:26 PM
XLR8R's Avatar
Actually, KROIL is the best at this sort of thing...
Old Sep 8, 2006 | 08:14 PM
JD730's Avatar
If you have or know where to get it that the stuff to use. I haven't found anything that works like KROIL.
Old Sep 8, 2006 | 08:19 PM
Geico266's Avatar
Kewl stuff! Where do you get it?
Old Sep 8, 2006 | 11:48 PM
53 willys's Avatar
if u cant find it at a parts store you can buy it at most gun shops and sporting goods stores in the gun cleaning section.
Kroil is KING
53
Old Sep 8, 2006 | 11:58 PM
XLR8R's Avatar
I order mine direct from KROIL (in TN, I believe) by the gallon, also in spray cans for the service trucks. Price is pretty reasonable that way.
Old Sep 10, 2006 | 11:41 AM
West Coast's Avatar
Ats
I took of my stock manifold today. Manifold is in excellent shape. No issues. so does the ATS manifold make a noticeable difference? And does the ATS manifold come pre drilled for a Pyro probe. And does it come with the complete gasket kit and bolts from scheiddiesel? Thanks.....
Dave
Old Sep 11, 2006 | 05:19 PM
West Coast's Avatar
manifold
Just recieved my ATS manifold. SWEET....!!! Already assembled from the factory....!!! And lines up perfect against my stock one..!!!!
Old Sep 11, 2006 | 07:16 PM
53 willys's Avatar
well put it in already and go haul some A$$
Old Sep 11, 2006 | 10:49 PM
West Coast's Avatar
in and running
Had a little issues with bolting the unit in. But it works great. Smoothed out the power and spools the turbo quicker. Sound quiter too, if that possible with a 12 valve......
DPatton
16
Oct 7, 2009 08:12 AM
1985cucv
Sep 9, 2009 09:48 PM
dodgethis91cmns
Mar 30, 2008 02:17 PM
1320
Jun 23, 2003 08:05 AM
