EVS II Help please
Old Feb 21, 2005 | 09:06 PM
flyfsh70's Avatar
EVS II Help please
Help, I bought the EVS II OEM alarm installation a breeze, Plug everything up try to start truck won't start. figre I'll just unplug the sentry key module witch is the only thin extra an nothing..
Please any help will be appreciated.
Old Feb 26, 2005 | 10:35 AM
RCW's Avatar
RCW
I would suspect you have fixed this by now, but the most common problem is installation without disconnecting the negative battery cables. Most often, disconnecting the negative battery cables, and letting all the capacitors drain for about 5 minutes is all that is required to get the system to reset after it has been improperly installed. Sometimes the PCM is blown in the process of hooking the EVS up hot, but that will show up as a series of ODBII error codes after you reconnect the batteries.
Old Feb 26, 2005 | 10:42 AM
J BODY's Avatar
In the past the sales literature has recommended that the EVS II system NOT be installed with vehicles already having the SKIM security. I've seen a number of tow ins for no start stemming from this.
brightrevenue
Jun 22, 2011 09:59 AM
atown
Jan 25, 2010 07:47 PM
s-cube
Oct 2, 2007 06:04 PM
SuperiorRam
Mar 15, 2007 03:10 AM
MoparRiggan
Jan 17, 2006 12:43 PM
