Engine noise
Old Jan 24, 2005 | 11:13 AM
Jerrod's Avatar
Engine noise
My engine sounds like its roaring when going down the road at any speed, rpms dont move just hear the roaring sound. I also have dead petal sometimes and just had the lift pump replaced because of a 0216 code, after it was replaced it still makes the roaring sound a 0500, 0216 and 1693 code come up. Is my VP44 dead? And is that what is making the noise?
Thanks
Old Jan 24, 2005 | 11:39 AM
P.O.R.'s Avatar
when the cooling fan is engaged it will make a roaring noise. i wonder if somthing is making it stay engaged all the time...
Old Jan 24, 2005 | 12:22 PM
neveragain's Avatar
Does it clatter? The roaring could be the fan working. What is your engine temp? Has it been high recently?
Old Jan 24, 2005 | 12:33 PM
WildBill's Avatar
code 0500 is Vehicle speed sensor, 0216 is Fuel injection pump timing failure - replacing a lift pump will not fix this problem, 1693 just means code in companion module - one computer says the other has a code - which is the 0500 and 0216 codes. The noise does sound like your fan clutch is stuck engaged - try & turn the fan - it should spin (with the engine off of course )
Old Jan 24, 2005 | 12:55 PM
Jerrod's Avatar
Fan spins great, I guess when I said roaring you would think the fan, but it really sounds like a groaning sound and it is constantly on off on off.
Smkn600CTD
May 22, 2012 07:21 PM
ShowMe06
27
Jan 4, 2008 11:47 AM
richard
Jan 18, 2003 08:55 PM
Gregor
Dec 3, 2002 12:18 AM
rattle_rattle
Nov 24, 2002 08:10 PM
