engine dies when put into gear
Old Aug 8, 2007 | 07:04 AM
badme's Avatar
I love it. When I bought it I got it for the guages, but it was only 1 day and I had the pump tapped. Wow. what a difference.
Old Aug 8, 2007 | 08:00 PM
mr bill's Avatar
I think after I save a little that will be the next purchase. I got the hypertech programer back in 2002 mainly do to the fact of warranty on truck and it would read codes or so they said it would. Also did not think I needed to much but after seeing the difference it made I got sucked in to wanting more power. Mine is going in Thursday and i'm looking forward to see the difference with the new pump and added power from new injectors
Old Aug 8, 2007 | 08:38 PM
badme's Avatar
My fuel mileage went up 2 mpg with a new vp44
Old Aug 9, 2009 | 06:22 PM
Geico266's Avatar
Did anyone figure out this stalling problem?
Old Aug 26, 2009 | 06:44 PM
bethrobct's Avatar
I have a 2001 3500 with the same exact problems as described in this thread. I spoke to the local transmission guru (Dodges are his specialty) and he said that its a classic case of a torque converter shelling out.
-Rob in CT
Old Aug 26, 2009 | 09:42 PM
Dr. Evil's Avatar
-Rob in CT
A dying torque converter will NOT give you a P0216 code.
Old Aug 26, 2009 | 09:52 PM
mr bill's Avatar
new VP44 and problem solved. Probaly not what you wanted to here.
Old Aug 27, 2009 | 07:15 PM
bethrobct's Avatar
Already had a new pumps installed (tank, lift and injector) and no codes present.
Old Sep 1, 2009 | 05:02 PM
bethrobct's Avatar
torque converter shelled out and took the transmission with it. The converter was trying to engage at idle. not good. $4K later we should have a truck again.
cowboykilla235
17
Feb 1, 2013 08:05 AM
mwolfe
Dec 2, 2006 05:29 PM
bailman
Dec 8, 2005 08:32 AM
bigjons
Mar 31, 2003 03:27 PM
