engine dies
Old May 19, 2006 | 07:24 AM
mooseman's Avatar
engine dies
Lately when I shift into drive or reverse my truck will die. If it don't die it will go into gear, rev and try to take off. Also when I turn the key to start, it sounds like its running so I let off the key and it will die then I try to restart and it will crank over numerous times before finally starting.
Both problems occur at any temps. After the trucks warmed up it seems to be a little worse.
Anyone have any ideas?
Thanks, Mooseman
Old May 20, 2006 | 07:22 PM
RCW's Avatar
RCW
Check your fuel pressure to the VP44, if it is good, then I would guess the VP44 is out. You should be able to read a fuel system related trouble code when the injection pump fails, but sometimes they do not issue a code, but simply die.
vintovka
Apr 30, 2012 12:38 PM
90 power ram
Oct 6, 2011 08:04 PM
1ST CUMNZ
Jul 21, 2003 07:33 AM
joken
May 14, 2003 06:47 PM
joken
May 14, 2003 05:47 PM
