ac oil
Old May 20, 2006 | 10:06 PM
akdennis1's Avatar
ac oil
95 Dodge 1 ton 4wd
How do I ck the AC compressor oil & how do I Add more?
Thanks
Old May 20, 2006 | 11:39 PM
volly818's Avatar
Is you a/c working properly or have you had a leak or changed a component? If it is working then the oil is fine. If not and you have changed something in the system then you should only have to add an ounce or so. New compressors come with oil in them as far as I know or at least all the ones I've done have.
ian515
Oct 16, 2007 07:02 PM
TxDiesel007
15
Jan 18, 2006 01:19 PM
