Emergency brake problem
Yesterday my e-brake let go. The cables all appear to be in good condition. When I step on the pedal, I hear a ting and no ratchet clicks like when it is working. Is this something I can fix or do I need a new pedal assembly? Thanks
Set the e-brake and look down on the frame where the main cable splits into the 2 cables that feed the rear wheels, you will see which one is broken. Drivers side right under back of cab, outside of frame.
Cheers, Kevin
Cheers, Kevin
ARbowhunter7
Dec 16, 2012 04:24 PM
NE frmhnd
Jul 17, 2010 07:13 PM
