Emergency brake problem
Old Jan 31, 2006 | 11:59 AM
RAW's Avatar
RAW
Howdy, all.
I've got an issue that I need help with.
I have a 2003 3500 dually. I just recently had the bed replaced at a car dealership that was selling some take-offs.
When I parked the truck to have the bed removed, the e-brake worked fine.
When I moved the truck to have the new bed put on, the e-brake didn't work.
And it still doesn't work now that the new bed (a 2005) is on.
The e-brake pedal has a fraction of the tension it used to have. But when I push it, I can see the cable and associated connectors moving at each rear wheel. The adjustment point just behind the cab looks to be tightened almost all the way down.
What could have changed when they took off the old bed? What should I look for?
Thanks in advance
Old Jan 31, 2006 | 01:17 PM
John Faughn's Avatar
Go back and have them fix it if its as you say.
Old Jan 31, 2006 | 02:19 PM
RAW's Avatar
RAW
Drove to Knoxville, TN to have bed swapped out.
I live in Georgia. Plus, the used-car dealership had no clue what I was talking about when I confronted them at the time.
Old Jan 31, 2006 | 02:30 PM
dencordle's Avatar
Have you followed the cable from the cab back and make sure that there arn't any brackets loose that hold it to frame. that will cause problems. I'm not sure if these trucks are set up like that or not, but IMO I would check.
Old Jan 31, 2006 | 03:21 PM
If theres nothing obvouse then it may be that sometimes there are metal hooks that go into the frame and rap around the cable and hold the cable in place , with one of those missing [ what I'm talking about are bacicly a hook at both ends and if unhooked at one end can fall off the other end ] then the hole thing has lost a large part of its tension , that the adjuster can not make up for .
Does it seem that there is a spot were the cable hangs down ?
Another one could be that at the end of the single cable going to the r. splits into 2 and at that point theres like a bar were 2 cables from both sides of the r. axial hook into a bar that has three posissions ,the third for the 1 going to the ft. and they may have bumped it and cocked to one side.
All this is generic , I'm not saying that this is whats under your yr & md , just what I've seen under the average truck.
Old Jan 31, 2006 | 05:49 PM
Casey Balvert's Avatar
My newphew had that happen to his truck. The little tiny brake shoes inside the drums of the rotors had disintegrated. Happened suddenly.
Old Jan 31, 2006 | 07:02 PM
rammtuff's Avatar
What he said. Might just be a coincidence.
Old Mar 1, 2006 | 04:08 PM
RAW's Avatar
RAW
Turns out it's the "backing plate" that is broken.
Dunno what the dealership is talking about.
But it's gonna cost $500 to get it fixed.
I'm gonna ask to see the broken parts. I wanna know what happened.
Old Mar 1, 2006 | 05:10 PM
I should cost a lot less to have welded , whatever .
ARbowhunter7
Dec 16, 2012 04:24 PM
NE frmhnd
Jul 17, 2010 07:13 PM
bulldog_bones
Sep 9, 2009 01:53 PM
Pike
Aug 29, 2004 11:08 AM
