EGT probe.
Old Sep 23, 2005 | 07:07 PM
jaymo's Avatar
EGT probe.
Well I bought a issapro egt and fuel gauge this week and am installing them rite now. But the thermocouple probe dose not have any threads. In the box it came in it only had two big hose clamps and on the probe itself There is a ring with an allen key in it. Did i get the wrong thing or did I get robbed?
Old Sep 23, 2005 | 07:11 PM
Marine's Avatar
Veteran: Marine Corp
The probe will not have any threads. There should be a collar that tightens around the thermocouple, and THAT screws into the hole.
It sounds like you got the one that is held on with 1 hose clamp on each side of the thermocouple.
Can you post a pic of it?
Old Sep 23, 2005 | 07:12 PM
jaymo's Avatar
Ill try right now If my cam will work.
Old Sep 23, 2005 | 07:45 PM
jaymo's Avatar
Hope this works
sorry it took so long I had to download my camera cd.
Old Sep 23, 2005 | 07:47 PM
jaymo's Avatar
Whats up with this? I thought I was buying a good product. I havent evan put it in and I feel robbed.
Old Sep 23, 2005 | 08:17 PM
jaymo's Avatar
now can I use this and still do it pre turbo? Or should I send it back?
Old Sep 23, 2005 | 08:19 PM
Marine's Avatar
This style is fine.
1.Take off the collar
2.slide thermocouple through hole in clamp
3. Place collar so that approx 1/2-3/4 of the thermocouple is in the exhaust
4.Tighten collar on thermocouple
5. Insert the thermocouple into the hole
6. Tighten clamp to hold thermocouple in place.
Make sense?
Old Sep 23, 2005 | 08:20 PM
Marine's Avatar
Pre turbo- I don't believe so. However, they should just be able to send you the correct fittings. Make sure you tell them where you are going to put it.
Old Sep 23, 2005 | 09:27 PM
Dr. Evil's Avatar
Theres different types of thermocouples and different ways to mount them. Make sure you know what you want before you order. Maybe you could send it back and get the correct T/C??
Old Sep 23, 2005 | 09:59 PM
jaymo's Avatar
I guess thats what Ill do . I will get all the wires run and the piller pod mounted and the on monday Ill call and try to sort it out. And yes I do want it pre turbo.
I actully orderd on line and there were not any options. I just assumed it would come out with the treaded pieces.
But you know what they say when you assume>>>
Thanks for the help.
tomd
Dec 12, 2006 10:56 PM
Drafter
May 10, 2003 10:51 AM
Drafter
Apr 16, 2003 10:58 AM
Scotty
Dec 7, 2002 08:28 AM
