Door power lock wiring question??
Old Jan 29, 2007 | 01:23 PM
imbodie's Avatar
Question Door power lock wiring question??
Ok, have a 2k 3500 that I had to replace the outside handle on. When I put it back together the power lock wont work. I KNOW what the problem is, just not sure what the fix is.
When you take the inside panel off and look directly below the lock slider there is a yellow wrapped set of wires that has a wiring harness plug on one end and a small switch/circuit board on the other... it's round and had a rubber boot around it. I KNOW this should go somewhere but its just hanging.
Anybody with a suggestion? I didn't see where it was when I took the door panel off to begin with. I almost think it just attached to the metal on the inside of the door.
HELP
-Tim
Old Jan 29, 2007 | 03:56 PM
2500Ram's Avatar
Any chance you can look on the passenger side without disconnecting the wire. Sorry no help here, I have manual locks.
Old Jan 29, 2007 | 04:12 PM
imbodie's Avatar
Talking Passenger side??
I'm betting you meant the driver's side, I will eventually have to remove the driver side panel. But I honestly don't think it will be on both sides. It's almost like its a computer delay for some reason. I'm hoping to get an answer before the drivers side panel has to come off, that way I'll have the info to fix it before I break it.
(prior owner took the speakers out of the doors and I'll have to pop the panels just to put new speakers back in.)
Thanks though,
Tim
JWSKJ
Feb 7, 2012 08:25 AM
Dynocon
Mar 4, 2008 08:32 PM
staarma
0
Oct 25, 2007 12:49 PM
xp8103
Jun 2, 2006 07:00 AM
Bobcat698
Jun 1, 2005 09:29 AM
