Doesn't Start
Doesn't Start
I started my truck and let it warm up for a min. or two than I started down the street. I got to the stop sign and stopped and than took off half way through the intersection it died and wouldn't start back up the electrical seems to be fine but acts like it isn't getting fuel. I have cracked the injector lines and when i crank it over there is fuel running out. Could there be a sensor or a fuse that could be causing this to happen.
Please Help thanks Lance
Last edited by Vanb; 03-08-2010 at 11:49 AM. Reason: Checked to see if it was getting fuel
p0252 injection pump fuel metering control a range/performance
p0602 powertrain control module programming error
p1682 charging system voltage too low
i'll bet if you fix the last code all others will go away
but on the other hand , the inj pump may be gone
Just for giggles...... reset ECM back to stock, clean battery terminals, pull alt and have it tested then try to start.
Low volt could be from cranking alot, dont test alt just yet.
glacial pump wont run, stock pump wont run, unless they are wired hot its like either of the pumps are getting a signal to turn on...... I have been at it all day with the truck checking relays ,fuses and looking over wires and im at a total loss!!!!!!!!!!!!!!!! PLEASE HELP
