Difficulty of exchanging a lift pump?
Old Jan 20, 2003 | 12:35 PM
cwbronc's Avatar
I have some mechanical knowledge on gassers, but none on diesils. Would I be able to change a lift pump? any special tools? Where exactley is it on a '95? do I need to do any prep work (ie. new seals, drain it)? Also, if I replace the lift pump, and the injector pump is bad, will it hurt anything? thanks for your time. cwbronc
Old Jan 20, 2003 | 03:47 PM
rich's Avatar
Re:Difficulty of exchanging a lift pump?
on the 12v the pump is mechanical not electrical it is located above the starter and below the fuel filter. It looks kinda like a mechanical fuel pump. Do you have reason to replace it . The best place to buy your motor parts is from cummins
Old Jan 20, 2003 | 04:05 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
The lift pump on the 95 while not infallible, is not prone to the failure problems of the newer electric pumps. That doesn't mean it can't fail but don't think of it in the same terms as you see in failure rate with the newer trucks.
Turbo Deeezle
Jan 24, 2005 08:41 PM
condensr
Dec 29, 2004 09:41 AM
suzukiZrider
Dec 20, 2004 09:22 PM
ouchman
Mar 15, 2004 08:17 PM
Randy J
Oct 28, 2003 07:56 PM
