Injector O-Rings - difficulty level?
Old Mar 13, 2004 | 08:12 PM
ouchman's Avatar
A few of my injectors look like they're leaking. How hard is it to change them (for someone who hasn't done them before)?
Where can I get an O-Ring kit?
Old Mar 13, 2004 | 10:45 PM
carl20320's Avatar
Where do your injectors look like they are leaking at? The only places I would think they could be leaking would be where the top line screws onto the injector ( no o-ring there) or the return line (copper banjo bolt). If you are seeing leakage anywhere else, there are other problems.
Give us a little more info to figure this one out.
As for how hard it is, it is not. I had never changed them before and ti took me about 1 1/2 hours from start to running truck. I made a slide type puller (necessary) and had a 3/4" pipe brush to clean everything out.
As for where to get the necessary hardware, that's easy ...Cummins.
Carl
Old Mar 14, 2004 | 06:38 AM
truknut's Avatar
Why the slide puller? I only ever did it once myself and the just pullrd right out. Lucky I guess. But even if you needed the puller, I would agree it is relatively simple. I also agree with potential leak areas(top nut or banjo fitting)
Old Mar 14, 2004 | 11:55 PM
Graeme's Avatar
That's the situation we all hope for, but that's the exception rather than the rule. Injectors can be downright obstinate.
Old Mar 15, 2004 | 12:47 AM
carl20320's Avatar
Just pulled mine out tonight after about 6 months in. Every one took several good pulls with the puller. I think I would be concerned if they just pulled out by hand.
Carl
Old Mar 15, 2004 | 08:17 PM
ouchman's Avatar
I'll check the top connections. I'll report back soon. Thanks!
RottnRam
May 9, 2013 08:06 PM
kawi600
Jun 3, 2006 04:04 PM
1320
Mar 8, 2005 08:56 PM
suzukiZrider
Dec 20, 2004 09:22 PM
