Death wobble ?
Old Mar 20, 2009 | 07:16 PM
DLittle's Avatar
Death wobble ?
Truck is a 1993 W250 auto. For about the last 2 to 3 months my truck has a bad steering problem. When you turn a corner and come back to straight the steering wheel goes from right to left or left to right and back and forth in that fashion for quite a while. Eventually it will stop only to come back at the next turn . The steering wheel moves all on it's own back and forth back and forth. You have to hold it to go striaght and the steering continues to move. I have replaced the following to try and fix the problem. Gear box,installed a borgensen steering shaft, new shocks, power steering pump and hoses, new king pin bushings and springs, switched wheels and tires, new warn hubs. I have not changed the tie rods they feel fine. Nice and tight.
I'm at a loss and tired of throwing money at it. Could the front axle ujoints cause this problem ? I've had the truck to 2 different shops and they don't have a clue. Any help. It's so bad the truck is almost not driveable. I NEED HELP IT'S GETTING OLD. Thanks
Old Mar 20, 2009 | 10:37 PM
jnicewan's Avatar
somethings probably loose, might help to have someone saw the steering wheel back and forth just like a inch or so while you are underneath watching for loose components. u-joints will not do this. also way back in the day i remember installing steering stabilizers on brand new trucks and very low mile trucks for this but it was for mainly a highway speed death wobble.
Old Mar 20, 2009 | 11:19 PM
rattlerbob5.9's Avatar
Check to see if the steering gearbox is bolted tight to the frame and then check the frame itself to see it has cracked or broken.
Old Mar 20, 2009 | 11:24 PM
DLittle's Avatar
Had steering box off to replace and checked plate and frame all were ok. No cracks or anything loose.
Old Mar 21, 2009 | 12:16 AM
torquefan's Avatar
I would definitely suspect a seized axle u-joint. As the front wheels steer, the seized joint will have to flex while it is turning. That will definitely give you a shake and make the steering wheel oscillate.
Old Mar 21, 2009 | 09:07 PM
dozer12216's Avatar
I gather this is not death wobble at high frequency. A slower frequency would be a locked or very tight u-joint at hub.
Old Mar 24, 2009 | 11:12 AM
offshorextreme's Avatar
ANY ONE A HAVING THIS PROBLEM WITH THERE DODGE I FOUND A COUPLE OF SITES WWW.SOLIDSTEEL.BIZ AND WWW.LUKESLINK.COM
725Gus
Mar 6, 2014 09:49 AM
Trooperthorn
Nov 30, 2010 12:06 AM
Jezzhuntin
Apr 11, 2007 04:52 PM
smokindodge1996
Feb 13, 2004 08:54 PM
moneypit
Sep 23, 2003 06:06 PM
