Death Wobble
Old Dec 14, 2008 | 05:48 PM
redneck_racer's Avatar
Death Wobble
I was told that my Truck had DEATH WOBBLE!! When I get up to speed and hit a small bump the whole front end shakes very violently. Tires are ballanced, hubs are good. It has a Skyjacker 4 inch lift with 36 inch tires. I was also told to tighten the trackbar but im not sure how. Please advise!!!
Old Dec 14, 2008 | 05:52 PM
Festus's Avatar
Refer to this thread: https://www.dieseltruckresource.com/...d.php?t=220996
In addition, BFG tires have been found to be a contributor as well.
Old Dec 14, 2008 | 05:59 PM
I understand that I should change all of that and I am when I get a chance. But what ca I do now to get it to stop??
Old Dec 14, 2008 | 06:13 PM
Holycack's Avatar
My 07 had it bad as well, after the whole front end was replaced and a wheel alignment was performed. Turned out the alignment shop adjusted my castor to stock values and with a lift the castor needs to be maxed out. I adjusted mine in 5 min. and DW is gone now. Not sure if a 97 has the ability adjust castor. Good luck.
Old Dec 14, 2008 | 06:24 PM
Radio-Flyer's Avatar
Thumbs up
Replace the bushing(s) and or heim joint on the track bar if it's loose.
725Gus
Mar 6, 2014 09:49 AM
Trooperthorn
Nov 30, 2010 12:06 AM
Jezzhuntin
Apr 11, 2007 04:52 PM
smokindodge1996
Feb 13, 2004 08:54 PM
moneypit
Sep 23, 2003 06:06 PM
