cummins to gm overdrive
Old Mar 29, 2004 | 11:36 PM
love-horsepower's Avatar
does any one have a cummins adapter kit to gm automatic for sale? 515-202-8090
Old Mar 30, 2004 | 06:30 AM
j-fox's Avatar
Why do you want to do this? Are you swapping a Cummins into a Chevy?
Try finding a 4bt Cummins from a bread truck, they have a chevy adapter on them. I just sold one!!
Old Mar 30, 2004 | 09:06 PM
bta3.9 cummins to gm trans
i have 3 bta and none of them have the adapter how much did you get out of yours i need 2 or 3 complete packages. do you know where to get them? rod
Old Apr 4, 2004 | 12:22 PM
RCW's Avatar
RCW
Advance has a package available to stick a GM 400 or the newer OD version of that transmission behind the B series Cummins. http://www.advanceadapters.com
These guys can get you the entire engine and automatic package in a used bread truck for cheap: http://www.chambersmotorco.com/
For the most part, it is not wise to use the GM automatic behind the 6, but limit it to the 4 Cummins, because the GM transmission case will crack where the servo cylinder is located from the torque generated by the 6. You used to be able to get some cases from B&M Hydromotive that would solve the cracking problem, but I have not seen them in years.
Old Apr 5, 2004 | 06:37 AM
jaconst's Avatar
check out www.fordcummins.com
Old Apr 6, 2004 | 12:56 AM
thanks i will call them tomorrow
72demon440
Apr 27, 2007 10:45 PM
olgraybeard
Mar 24, 2003 06:32 AM
pappyman
Dec 17, 2002 06:41 PM
marsh1946
Dec 5, 2002 12:55 PM
