do any other blocks crack, important to me
Old Apr 5, 2004 | 08:25 PM
Haulin_in_Dixie's Avatar
I am about to go to Indiana to purchase an engine. It is not a #53 block but is an early 1999 build. It has the small numbers at the pan rail. Has anyone ever heard of a different series of blocks cracking. This time I am having to go into debt to get this and I would be a disaster if it cracked. Thanks....
Old Apr 5, 2004 | 08:56 PM
phox_mulder's Avatar
Everything I've seen, here and other Diesel forums leads me to believe that only the "53" is prone to cracking.
Something about where and how it was cast led to the thin walls.
phox
Old Apr 6, 2004 | 02:36 PM
RCW's Avatar
RCW
Only the 53 is crack prone.
However, I have a fix for the cracks that works if you are interested and can do the welding yourself. It is a bit labor intensive and requires the left fender and inner panel be removed to get to the block where it cracks above the skirt.
PM me if you are interested. I have done several of these now, and they are all still on the road.
wrenchmaster
27
Jul 24, 2015 07:45 AM
realest
Jul 30, 2010 11:10 AM
Katmandu
Jan 16, 2006 08:30 AM
