Do all 53 blocks crack?
Old Jun 9, 2009 | 11:24 AM
wrenchmaster's Avatar
If you have a 53 block let me know if it cracked or not and how many miles you had or have on the truck.
Old Jun 9, 2009 | 12:14 PM
klx650a2's Avatar
I don't have a 53, but I've heard of many people with 200+K on them still going strong. Some guys are making big HP too....
Old Jun 9, 2009 | 12:55 PM
high bid's Avatar
knock on wood....doing just fine w/185k.
do a search on here for 53 block....someone recently took a survey on this subject.
Old Jun 9, 2009 | 01:20 PM
Dr. Evil's Avatar
Only a small percentage crack but it isnt a cheap fix if yours does crack.
So far, mines been good.
Old Jun 9, 2009 | 03:41 PM
GAK30's Avatar
My '98 has 218,000 with no cracks.
Old Jun 9, 2009 | 07:36 PM
rich's Avatar
the 98.5 in my sig with the 270k plus miles had the 53 and was chipped never had a problem other then going thru 7 nv4500
Old Jun 13, 2009 | 01:56 PM
Timmay2's Avatar
Bought my old 99 at about 210k and ran it HARD with edge comp and edge 5 nozzles and the block was fine up to 275k when she was decommisioned.
Old Jun 13, 2009 | 03:51 PM
VicR's Avatar
There was an article an issue or 2 back in TDR that you could pull a freeze plug and take a measurement and see if it was likely to crack. I've never heard of anyone doing that though.
-Vic
Old Jun 13, 2009 | 06:38 PM
decommisioned.. you mean it cracked???
Old Jun 13, 2009 | 08:03 PM
nickg's Avatar
435,000kms (approx 270,000miles) no issues yet driven hard daily. (8-10hrs of use), if it cracks tomorrow I've gotten my use out of it, and in the 140,000kms I've put on has cost me 25,000$ in fuel in the last 2yrs
I believe its a small percentage that cracks
Old Jun 29, 2009 | 07:22 PM
diggerfan99's Avatar
53 block
Ok guys I wanted to chime in on the 53 block disscussion. I have a 1999 with a 53 block that cracked at 108,000 miles from rear freeze plug to the block heater! I bought the truck used and little did I know that it had already been repaired.(which is why it diddn't leak when I bought it), it was a lock n stitch repair, which was no good, so don't do it. At one point I was leaking almost 2 gallons a week driving the truck every day. I finally talked to a friend of mine who owns his own welding company and is very good with cast iron. We took the truck apart and welded the crack and put a cast iron patch over it. I have done this twice, the first time it lasted a year before the leak came back, but the second time we used a bigger patch and I am going on two years with just a tiny bit of seeping out of the vertical weld in the back, nothing to even worry about. Just wanted to give you some info, if you have any questions, I will be happy to help.
Old Jun 29, 2009 | 10:59 PM
SO5.9's Avatar
195k on my 01. chipped and injectors since 115k. no cracks on my 53.
Old Jul 5, 2009 | 09:34 AM
Tocapet's Avatar
When I bought my '99, I discovered it had the 53. So, I did a LOT of research and found that the 53 blocks were cast in Brazil. SOME of the molds shifted during casting and as a result the block can be thinner at certain points. These are the ones that crack. Some guys pull a freeze plug and put a micrometer on the block to see if it's thick enough. I finally quit worrying and mine did just fine. Never cracked. Traded it off because of the high price of dizzle fyool. Now driving a little Ford Focus, but miss that truck!
Old Jul 5, 2009 | 10:11 AM
torqmonster's Avatar
98 12v, 53 Block, 136,000 miles, still throwin black smoke & pullin like a freight train!
Old Jul 5, 2009 | 01:08 PM
Dr. Evil's Avatar
I believe there are very few cracked 12V 3 blocks that have craaked. I dont think its an issue with teh 12V. But it is with the 24V due to different harmonics.
