Crankshaft Position Sensor Removal
Old Apr 25, 2010 | 03:24 PM
CODODGE2500MAN's Avatar
Got the starter out, bolt holding the sensor out, wires disconnected and the sensor itself spinning from 7-2 o'clock position.
Now what?
Does it have to line up to come out (ie 9 oclock poition vs. 12oclock position)?
TIA
Old Apr 25, 2010 | 03:30 PM
it almost looks like it is hitting the dipstick tube...
Old Apr 25, 2010 | 04:02 PM
Well now the elbow broke off and I have to decide how to get it out.
Should I just use some vicegrips and try to pull on the wires to pull it out, or try to pry it out with a screwdriver, or?
Any help?
Old Apr 25, 2010 | 05:33 PM
OldDodgeOwner's Avatar
I don't believe there's anything needs aligned. Should come out in any position.
I think a screwdriver would probably work fine, just don't want to scar up the inside of the hole so the o-ring doesn't seal.
Old Apr 26, 2010 | 06:52 AM
kthiemann's Avatar
The thing is probably stuck on it's o ring, a lot of times when they break on me like that I will take a small pick or pocket screwdriver and use it to carefully bend the plastic until I can grab it with a pair of needlenose...it can take some time but once you get it deformed enough for the o-ring to get loose it should just pull out of the hole.When I put the new one in I normally lube up the o-ring with some light grease and it should just pop in.
Old Apr 26, 2010 | 07:01 AM
Been trying to pry it out for a while with screw driver. No luck....
Any other ideas?
Old Apr 26, 2010 | 10:36 AM
rebal's Avatar
try a screw driver on two sides it should pop out . if that don't work try to run a screw in it and use vise grips and a pry tool
Wild Bill
Jan 21, 2005 03:35 AM
James Andres
Dec 20, 2003 04:42 PM
Two Dogs
Jul 11, 2003 09:12 AM
ATEAV8GN
Apr 1, 2003 08:03 AM
