codes and ccd in overhead console
i have codes p0622 and p1693 and on my overhead it shows ccd i have gone through the posts to see what it is and everyone says what the code means. i know what it means i just want to know what everyone who has had this problem did to fix it. dont say clean grounds make sure conections are right. i just want to know what exact wire was causing it for you.
I doubt if anyone can do your diagnois down to the exact point where a wire is shorted. You might secure a FSM as a great aid. Code P0622 has to do with a generator wire shorted! Is the alternator working correctlly???
Cummins Guru
P0622 : 0B : GENERATOR FIELD NOT SWITCHING PROPERLY; Mil on : K125 circuit wire possibly rubbing againest the air box bolt, cause a short to ground.;Follow all appropriate diagnostics for the fault that is present. Prior to replacing parts, please review the explanation below in the recommendation field.
System or Component Customer Concern (No DTCs);Instrument Panel / Cluster,Warning / Indicator Lights,Malfunction Indicator Light / MIL / Check Engine Light;Yes - Intermittent,Yes - Continuously
Recommendation T125 DB circuit wire possibly rubbing against the air box bolt or the manifold near the dip stick tube causing damage to the PCM
robert78.5
17
07-22-2015 03:06 PM
BlackSheep5
12-20-2007 03:26 PM
ebodragon87
11-13-2007 11:30 PM
