Clutch Master Cylinder Help
Old Mar 31, 2006 | 06:43 PM
90firstgen's Avatar
I have a new master cylinder for my clutch and I went to put it on and I cant figure out how to get the pushrod disconnected from the petal. I cant find a snap ring or nut or anything of the sort... Anybody done this before? Thanks in advance guys
PS.... 90 3/4 ton 2 wheel drive
Old Apr 2, 2006 | 10:09 AM
scuzman00's Avatar
clutch pedal probs
If I remember correctly, mine had a C-clip and a pressure type washer which held the rod to the pedal ssembly. It was the hardest thing I had to overcome when I replaced my master/slave assy when it went out. It was a royal pain in the patootie to dis-assemble and reassemble. I will go out in a bit and look at it again, but then remember mine is an 02 model so things may have changed....
Good luck with it..
Gary
Old Apr 2, 2006 | 02:19 PM
RCW's Avatar
RCW
Up under the dash you will find the swing arm assembly for the clutch. Remove the clip from the end of the retaining pin for the push rod where it joins the clutch pedal arm. Then pull the tapered washer, most also have a flat washer, then slide the push rod end off the pin. You should have a clip, a cupped washer, a flat washer, the rod end, and then a bushing that goes over the pin on the clutch lever and on which the push rod end rides.
Be sure to inspect that bushing that goes over the clutch arm pin and on which the push rod rides. If it is worn with an egg shaped hole, replace it or you will never get your clutch to disengage properly.
Gen414
May 7, 2009 11:08 AM
cgmorgan06
Nov 15, 2007 04:02 PM
WACTD
Jul 25, 2006 11:41 AM
Fishbait
Jun 6, 2006 12:34 PM
90firstgen
Apr 1, 2006 07:05 PM
