Clutch gone?
and yea there is plenty of fluid in the resevior, also i forgot to mention right when all this happened i smelled a stron oeder of brake fluid i am guessing it is from the master cylinder which is leaking now..i wish i had more time to work on my truck but between work, school and crappy weather i havent been able to get out there and work on it.
Originally Posted by heavyboostin
ok, so at lunch i went home and put the truck in first and put the clutch to the floor then i cranked her and she moved, what does that tell you? no wierd sounds are coming from the gearbox when the truck is running and in nuetral, it wanted to hop alot until i let the clutch completly out in first gear then she went along smooth until i turned the truck off......so I am at a loss, I may just replace the slave and master cylinders and then remove the trans if the slave and master cylinders dont do the trick.???sound good?? is there any more info i can let you know?
Keep us posted as to the fix.
well i took her apart tonight, didnt get the trans out yet cause i ddint have an extra set of hands and ddint want to risk killing myself, lol. but i looked in the vent at teh bottom of the trans and can see pieces off clutch i guess i know waht happened, i am willing to bet the springs came apart...or something like that
Sounds like a new clutch plate is due. Maybe the pressure plate also. While it is apart, don't forget to install a new throwout bearing , even if yours looks and feels OK.
yea i will def. do that, i just bought a clutch kit from luks, unless there is a big clutch in the truck which the 1st owner claims, but from the looks of things this transmission has never been out of the truck, ill keep you posted, my dad is going to give me a hand taking the trans out tonight, thats all that left.
well got her all apart and came to find a broken input shaft. Good news is my clutch is fine(mcloud street twin). Anyway, I am going to put a stock clutch back in the truck since i am selling, anyone know how much i could get for the clutch, plenty of life left, only like 20k on it mayb a lil less. my friend sold the same one for 650 this past summer, so i am wondering what i can get out of it. Ill put some pics up of the shaft and everythign for you all to look at.
Kevin
Kevin
Interesting. I am however puzzled how the truck would move at all with a broken input shaft. Is it a clean break or is it broken on a diagonal?
TAMU
May 27, 2009 06:34 PM
TAMU
Apr 27, 2009 11:26 AM
