Charging System Nightmare (re-thread)
Old Jun 29, 2005 | 11:51 AM
mhuppertz's Avatar
I took the alt to AutoScum to test, but I already knew it would pass even though it was bad. It did pass, but they only had the alternators with dual v-belt pulleys. They tried to get my pulley off and boogered it all up, so I had to go to NAPA and pay about $65 more for their alt. It’s lifetime warranty, but still.
I slapped that baby and reverted to the PCM’s regulator, and it is working perfectly. All the trouble lights have gone off, including the “water” light.
Now I can grind the AFC tang off!
Thanks for everyone’s help.
Mark
Old Jun 29, 2005 | 12:43 PM
mhuppertz's Avatar
My "resume" still doesn't work though.... I think it's the $%# clock spring again. I'm going to check the switch with an OHM meter, but it feels fine when I take it out and work it. I don't think I'm up for yanking the steering wheel the change the clockspring though!
Mark
Old Jun 29, 2005 | 03:34 PM
Glad to hear you got it working right.
You're my kind of guy - not interested in pulling the steering wheel to fix the cruise, but ready to rip the top off the pump to make more power.
Old Jun 29, 2005 | 07:50 PM
bmoeller's Avatar
Glad you got it working again.
The moron at my local AutoZone damaged my pulley also. Had to get a new one elsewhere. Went back, and they reimbursed me forth pulley.
Old Jun 29, 2005 | 10:10 PM
mhuppertz's Avatar
Postscript:
Ist day driving the truck, happier than a pig in poo, then the belt fragged! Brand new Gates from Napa.... limped to Napa on threads, go a new belt, limped on less threads to Harbor Freight to get a breaker bar for the auto-tensioner, waited till the engine was cool enough to stop splitting atoms (I found out fingers plump when you cook-em)
then spent much time unthreading belt web from pumps, fans, compressors, and what not, then finally got the new one in. I checked alignment in the pulleys and everything looks good to me. It's possible I didn't put the belt on right last night, in the dark and all!
Hope it holds long enough for me to grind on the PUMP!!!!!!!
Thanks Dave and BMoller!
Mark
Old Jun 30, 2005 | 04:14 PM
It's not hot down there in NM this time of year, is it?
Old Jun 30, 2005 | 10:26 PM
bmoeller's Avatar
If the belt frags again, check the tensioner. Either the bearing could be bad, or the pivot point on the tensioner takes a dump.
Old Jun 30, 2005 | 11:07 PM
mhuppertz's Avatar
It's been near 100 every day. The belt held today thank goodness. I'm going to try to get the cryo unit up and running this weekend. I'm considering adding water to the CO2 spray to add capacity (a la siphon tube). I don't think this has been done before, so what the heck!
Old Jul 2, 2005 | 05:15 AM
Jim Lane's Avatar
alternator
Mark
Hey now would have been the perfect time to rip out that little bicycle alternator out and install a real alternator like I did. I installed a Leece Neville 110-555 OTR unit in place of the ND unit. Instructions are in the Tech Facts. 85 amps @ idle
Anyhow, glad you got it working, it is so frusterating when you can't figure something out..
Jim.
Old Jul 2, 2005 | 08:44 AM
mhuppertz's Avatar
Now you tell me!
An interesting side note:
I noticed that the bad alternator was pumping out so much RF that my garage door opener was being jammed and I even had interference on my FM stations!
Mark
Old Jul 2, 2005 | 10:45 AM
Jim Lane's Avatar
Sounds like you had your own Dodge AWACS
Old Jul 2, 2005 | 11:39 AM
mhuppertz's Avatar
Yea, I guess that's why the NSA and the FCC were all over me!
I should have contracted with the Marines and idle my truck areoung Bagdad!
Diesel-Dan
20
Sep 22, 2019 09:34 PM
GLHS
Feb 25, 2011 10:12 PM
rockmike
Jun 9, 2010 07:16 PM
Smokin96_12v
Jan 21, 2010 01:06 PM
NWDave
Mar 27, 2003 12:10 AM
