Can't get water pump off
Old Feb 28, 2010 | 12:21 PM
dodchall70's Avatar
I am in the process of replacing the water pump on my truck. Got the 2 bolts off but the pump won't budge. Any ideas?
Thanks Larry
Old Feb 28, 2010 | 12:28 PM
dodchall70's Avatar
Got it
Old Feb 28, 2010 | 01:22 PM
madhat's Avatar
Administrator/Jarhead
Well, what did you do to get it off?
Old Feb 28, 2010 | 02:48 PM
Probably got a bigger hammer.
Old Feb 28, 2010 | 03:01 PM
madhat's Avatar
Yeah, that's what I was thinking... maybe he found a water pump removal tool or something...
Old Feb 28, 2010 | 03:19 PM
Onemoparnut's Avatar
If at first it dosent work use a bigger hammer!!!!!
Old Feb 28, 2010 | 03:21 PM
dodchall70's Avatar
Yep, just a bigger hammer. Works every time No actually I did just keep pounding on it little by little and it finally broke loose.
Old Mar 1, 2010 | 09:48 AM
infidel's Avatar
When they're hard to get off often the o-ring is pressed flat on the block and can be hard to see.
Make sure you scrape it off or the new pump will leak.
Old Mar 1, 2010 | 06:53 PM
Mainemike100's Avatar
Don't force it, just use a bigger hammer. Works every time.
Totallyrad
Jul 19, 2011 07:41 AM
4969joes
Mar 28, 2010 05:26 PM
runamuk
Jan 14, 2006 07:48 PM
PapaPerk
Nov 10, 2005 07:15 PM
