camshaft sensor
Old Aug 22, 2007 | 09:14 AM
hejo's Avatar
camshaft sensor
Could someone tell me where the camshaft sensor is located on a 2001 dodge diesel
Old Aug 22, 2007 | 09:33 AM
infidel's Avatar
Not sure on an "01, earlier models #10 below
Old Aug 22, 2007 | 09:57 AM
1-5-3-6-2-4's Avatar
How does that measure the Camshaft, from down by the pan rail?
Old Aug 22, 2007 | 11:47 AM
pind's Avatar
the cam sensor on an 01, is up underneath the injection pump, toward the blcok, and sits in the rear of the gear housing. It requires a 10mm socket to remove, along with a lot of patience.
If you are changing an injector pump, that is the best time to do one, as everything is out of the way.
Old Aug 22, 2007 | 04:39 PM
phox_mulder's Avatar
Isn't #10 the Crank Sensor?
I can never remember which one got deleted in the later 24valve trucks.
I know 98.5-2000 (or was it 1999) had both the cam and crank sensors, but after that there is only one that performs both functions.
phox
Old Aug 22, 2007 | 07:05 PM
slim51015's Avatar
The cam sensor is #11 on infidel's post.
Old Aug 22, 2007 | 08:39 PM
J BODY's Avatar
phox
They went to "cam" only on the 01 02.
Mike D
Sep 27, 2007 03:28 PM
MikeyB
416
Oct 25, 2006 10:29 AM
Gene007
0
Feb 26, 2006 04:31 PM
SilverRam01
18
Nov 28, 2005 11:54 PM
hustler
Mar 31, 2004 08:07 AM
