Location of camshaft sensor? Help!
Old Mar 25, 2004 | 08:22 PM
hustler's Avatar
I have a '99 Dodge 2500 w/ Cummins diesel. The check engine light came on a few days ago. After taking it to the dealer, I was told the problem was the 'cam shaft sensor'. Anyone have any idea where that sucker is hiding on my motor. Pictures or diagram/drawings would be helpful. By the way, great website-I'm glad I found it!
Thanks for any feedback.
Ron
Old Mar 25, 2004 | 09:03 PM
Sootman's Avatar
If your truck is a 99 you have a crankshaft sensor. Camshaft sensors started in 2000 I think. The crankshaft sensor is located down by the lift pump.
Old Mar 25, 2004 | 09:12 PM
Barney's Avatar
Here is a graphic of the layout of most of the 24V sensors and components.
http://www.dodgeram.org/tech/dsl/mt_...l_sys_comp.htm
Old Mar 25, 2004 | 11:02 PM
J BODY's Avatar
They are located below the fuel injection pump. Have fun getting that sucker!!
Old Mar 29, 2004 | 06:36 PM
Scrambler250's Avatar
If it's the crank sensor, then none of this applies and I'm just rambling...
If it's the cam position sensor, I can do it with my eyes closed...because I couldn't find any possible way to see it. It took me about twice as long to get it out as it did to put it back in. When you reach below the injection pump, run your hand along the block, towards the cylinders. There's a a group of (three?) wires running into a plug, and an allen head bold holding it in. Wish I could remember what size socket you'll need...
Old Mar 30, 2004 | 06:25 PM
hustler's Avatar
HELP!!!
Hey Barney (or anyone),
On the diagram that's included on your post, it doesn't say "cam shaft sensor" anywhere. Is it possibly #11 - CMP sensor?
HELP!!!!!!!!!!!!!!!!!!
Old Mar 30, 2004 | 06:27 PM
Shovelhead's Avatar
Administrator / Scooter Bum
'Dat's da one.
Old Mar 30, 2004 | 09:56 PM
hustler's Avatar
Alright!
What a PAIN in the ***! I swear, they build these new trucks so you CAN"T work on them! Now I know why I always see that one skinny *** mechanic at every dealership. You have to have some skinny hands and arms to work on 90% off this stuff. Here I am crammin' my big ol' paws down under that injector pump. And once I finally got 'em in, I couldn't see or feel a **** thing! But here it is two hours later and the suckers mine!
Thanks for the info. This sure is a great site for shadetree mechanic's like myself.
Oh, and by the way, it is a 3 wire plug and the hex head bolt was 3/16".
Thanks again!
Ron
Old Mar 31, 2004 | 08:07 AM
J BODY's Avatar
I could here the cussing all the way out here!!
dodge-dodge
Apr 24, 2020 12:34 AM
supercharged_hp
Oct 29, 2008 03:34 PM
Mike D
Sep 27, 2007 03:28 PM
59FORD
Apr 7, 2006 12:28 AM
Gene007
0
Feb 26, 2006 04:31 PM
