Cam/Crankshaft Sensor
Old Apr 30, 2007 | 03:43 PM
efrantz's Avatar
My check engine light came on and took the truck to autozone they saide it was a chankshaft position sensor. but is there a possibility that it is a cam sensor. my truck is a 2000 2500 4x4 does it have a cam sensor. also what sensor causes the tach to bounce.
Old Apr 30, 2007 | 07:29 PM
dieselrob's Avatar
Its your crank position sensor. I think in 01 and up they changed the place and called it the cam sensor, nut shure there. Yours is directly under your vp44, real pita to get at, but they are pretty cheap. If you under the truck you should be able to get to it.
Mike D
Sep 27, 2007 03:28 PM
Gabe32
16
Feb 22, 2007 06:37 PM
Two Dogs
Jul 11, 2003 09:12 AM
ATEAV8GN
Apr 1, 2003 08:03 AM
