a/c line crack
Old Aug 8, 2005 | 04:18 PM
Jambbii's Avatar
a/c line crack
Well its my fauld I cracked the line (low side) comming right out of the firewall. I can get the whole system evacuated and charged for dirt cheap but the bad thing is the crack is on the evaporator line which means I have to get a new one or pull the entire thing to get it fixed. I need something to get me through the summer (3 more months of hot weather) So I was thinking maybe I could fix/rig it with some sort of epoxy or maybe even JB weld until I feel like pulling the dash apart. Any input would be appreciated.
Thanks
Old Aug 8, 2005 | 09:17 PM
MnTom's Avatar
I highly doubt that JB would hold. If you really want to try to fix it go to a hardware store and there you should be able to find a repair kit for aluminum (I believe the lines are aluminum). I mean the kind where you can use a propane torch to effect repairs. Be careful and keep a live water hose handy.
Tom
Stamey's Avatar
I've never tried it, but I have heard of others who have patched lines with epoxy of some kind. You might even be able to solder it.
Chris
Old Aug 9, 2005 | 10:57 PM
2 busy's Avatar
epoxy should hold on the low side, only problem will be when it isn't running and system equalizes. I know we have used epoxy on freezers before. just make sure you get all the oil off the line before applying. might use some emory cloth to scuff it up for some anchor points for epoxy.
Old Aug 10, 2005 | 01:38 AM
Jambbii's Avatar
Cool thanks for the suggestions. Anyone know how much psi the system is when equalized?
Old Aug 10, 2005 | 01:52 AM
2 busy's Avatar
134a can will reach 124 psi at 100 degrees F.be sure and get epoxy for use on alum. might need to try an A/C supply store.
just be careful when checking the system. stay out of the line of fire if epoxy comes loose. it took about 400psi to get the epoxy we used on the freezer coil to come loose. left hand didn't know what the right hand was doing with the regulator. sorry i dont remember the product we used 10 years ago.
Old Aug 10, 2005 | 01:56 AM
Jambbii's Avatar
Cool, thanks
w250_93
14
Jun 16, 2020 09:31 PM
Haulin_in_Dixie
Apr 6, 2004 02:36 PM
USMC64-70
Feb 3, 2004 09:58 PM
Monty
Dec 13, 2002 02:43 AM
