broke down
Old Nov 21, 2008 | 10:31 PM
annabelle's Avatar
Hopefully ,the reset will work. However, mine only went about a week before I needed to replace the APPS. That was after multiple reset procedures, but the first reset lasted me about a week and got me home.
Old Nov 21, 2008 | 10:35 PM
jj3500's Avatar
Codes.... 1693 and 0121.
Old Nov 21, 2008 | 10:42 PM
annabelle's Avatar
0221 Throttle/pedal position sensor
1693 Turbo charge control circuit malfunction........same as I got for APPS
Old Nov 21, 2008 | 10:49 PM
CrashCade's Avatar
So looking at those codes it looks like it is the APPS. Try the reset and see if things get better. If so, then you know that is what your problem is. I would start looking for a new one and maybe contact the member mentioned above. Best of luck let us know if resetting it worked for you.
Old Nov 21, 2008 | 10:52 PM
annabelle's Avatar
Timbo01 does have to ship his to you, but it is worth the wait if you can get home. Do a search under his name. Very nice man.
Old Nov 21, 2008 | 10:58 PM
johnh's Avatar
i don't know where you got your information, but it's wrong
Throttle position sensor is P0121
P1693 is: a companion DTC was set in both the ECM and PCM.....
Old Nov 21, 2008 | 11:02 PM
jj3500's Avatar
truck is in my driveway now. Its midnight here in N.Y. and its also 22 degrees. I'll head out first thing in the A.M.
thanks...I'll give feedback.
Old Nov 21, 2008 | 11:03 PM
annabelle's Avatar
My info says P0121 throttle position sensor/switch a curcuit range/performance problem 1693 as I stated.....from code reader from Harbor Freight. Sorry, my bad typing on the 0221.
Old Nov 23, 2008 | 01:41 PM
jj3500's Avatar
Thanks all for your input. I reset it with the link from Diesel Burner's posting. Engine light is now off. Well...if this does happen again, I'm prepared.
Thanks!
Old Nov 23, 2008 | 02:10 PM
annabelle's Avatar
Just be warned that Timbo01's unit takes a couple of days to get to you ( if it's the APPS) much less $ than the $500.00 from Dodge......Cummins here said they didn't carry it. Might be worth the cost to have a spare if you are on the road a lot. I was told it is a much superior unit.
smokeum99ta
Dec 8, 2017 01:32 AM
RAW
Oct 17, 2003 08:46 AM
yz
Dec 31, 2002 11:47 PM
