Brake pull
Old Sep 12, 2006 | 08:22 PM
redpoint5's Avatar
Brake pull
My rig is pulling to the right when I come to a stop. Took the wheels off and inspected the rotors and pads. They look good and do not pulse. There is what appears to be a rubber seal of some sort that is around the brake piston and it seems to be damaged on my truck. I cleaned the brakes with brake cleaner and this resolved the pulling issue for a couple weeks before returning.
I don't have a noticable drop in my brake fluid levels, but I imagine a small amount of fluid on the brakes could still cause this problem.
What do you think? Is there a kit I can purchase that replaces the rubber seal, or do I need to replace the entire caliper? How much would this cost? I see this as a safety issue and would like to get this resolved without unnecicary time or expense.
Old Sep 12, 2006 | 08:33 PM
handymantim's Avatar
Yes there is a kit you can buy but you'd be better off buying a new or rebuilt caliper. To properly install a kit you have to hone the old caliper which requires the special honing tool and a lot of hassle and "what if its going to work" after installing the kit.
Old Sep 12, 2006 | 09:16 PM
RCW's Avatar
RCW
The Dodges wear the caliper bores into a taper. That causes the pucks to lock up one one side or the other, and then most of the braking will be done by the other side.
I always advise that the entire caliper be replaced with a professionally rebuilt or new packed unit. The cost will range from around $40 to $65 per wheel.
If you do your own work and have ABS, it does not bleed the same way cars and trucks used to. It is advisable to pick up the procedure on bleeding so you do not airlock the ABS and create more problems and costs than necessary.
Old Sep 12, 2006 | 09:45 PM
runamuk's Avatar
Yup, sorry to say the calipers are the culprit I went through 3 sets of pads and rotors before I discovered this
Don't make the same mistake!
Rick
Old Sep 12, 2006 | 10:52 PM
973604x4's Avatar
my right caliper was just cleaned up and its been fine ever since.
Old Sep 13, 2006 | 03:42 AM
redpoint5's Avatar
Thanks for the feedback. Looks like there is a consensus. Seems like those parts aren't as expensive as I had imagined, so I will be replacing them when I get some time. Don't have front ABS, so that should not get me into trouble, thanks for the heads up.
Old Sep 15, 2006 | 09:52 PM
mr T's Avatar
get urself a new caliper..its 35$ at NAPA...one of the best deals out there is calipers...u can get them cheaper at advance or autozone i imagine..
Old Sep 20, 2006 | 10:58 PM
redpoint5's Avatar
Bought remanufactured calipers at a local parts store for $30 each. Installing them was easy and they came with everything needed. So far my truck is stopping with less effort and does not pull. Time will tell if the pull comes back, but my guess is that the problem is resolved.
92smokin blacky
Jun 11, 2009 10:17 AM
dodgemaniac
Competition / Pulls / OffRoad
Aug 5, 2007 12:42 PM
PourinDiesel
Jul 21, 2007 12:42 PM
Bobcat698
18
Aug 3, 2006 09:23 PM
zookeeper
Jul 19, 2005 09:40 PM
