Boy I messed up Good!
Old Nov 5, 2006 | 06:15 PM
wilderness's Avatar
I was trying to hook up my pyro tonight and was looking for switched power on the back of the fuse panel. Well I found it, I had my meter wires plugged in wrong and was grounding the blue wire behind the radio fuse. Well I continued with the install and when I started the truck the instrument cluster does'nt work now. No wait to start, no voltage, rpm's, check engine, but the lights work when you turn the head lights on. I unhooked the gauge ad soon as the lights started dimming. I checked all the fuses inside and under the hood. I hope I did'nt fry the pcm! Is there a fuseable link for the instrument cluster or a fuse I don't know about? I really need some help!
Old Nov 5, 2006 | 06:48 PM
wilderness's Avatar
OK I fixed it. It was the ABS fuse. That fuse controlls several things.
Tfeore
Feb 7, 2007 08:10 PM
Nate-03 D
Dec 21, 2006 04:14 PM
BigBlue
31
Nov 7, 2006 06:18 PM
Viesel
13
Sep 13, 2005 10:14 AM
Wade
Oct 25, 2002 05:20 PM
