Banjo Bolt
Old Jan 28, 2006 | 12:36 PM
T.B.'s Avatar
Banjo Bolt
I Was Tryin To Conect My Fp Gauge An The Banjo Bolt Snapted Off Is Thare Any Way To Get The Bolt Out Of The Filter With Out Drilling
Old Jan 28, 2006 | 12:48 PM
Vulcan's Avatar
Can you get a small easy out in there?
Old Jan 28, 2006 | 01:09 PM
srt20's Avatar
i had this happen just this week also, i had thread tape on mine, anyway mine broke at the holes so what i was gonna do was use a large flat blade screwdriver to turn it out. as soon as i put the screwdriver on it i noticed it was loose, so i just turned it out with my fingers. have you tried turning it yet?
Old Jan 28, 2006 | 01:21 PM
T.B.'s Avatar
I Stoped Cryin And Got Over The Sick Feeling And Was Abill To Pull The Line Down And Get A Vise Grip On It And Get It Out Thanks For The Reply
Old Jan 28, 2006 | 01:42 PM
srt20's Avatar
lol, i know the feeling. when i broke mine i was a half a second away from seeing how hard i could bounce the wrench off the concrete cuz its always the darn tools fault
Old Jan 28, 2006 | 02:31 PM
440forPOWER's Avatar
Do you guys recommend teflon tape on the gauge fitting? Will it seal without? thanks
Old Jan 28, 2006 | 02:43 PM
srt20's Avatar
i didnt use it at first and it did leak. so i used it. i thought i had seen posts somewhere about not using it, but i dont know why? so i guess i will use it when i get my new banjo bolt in.
Old Jan 28, 2006 | 03:04 PM
phox_mulder's Avatar
You don't want to use teflon tape anywhere in the fuel system.
Small pieces of it will come off and go into the injection pump or injectors and mess either up.
Teflon paste on the other hand could be used, sparingly.
phox
Old Jan 28, 2006 | 03:07 PM
Geico266's Avatar
phox
I agree! NEVER use teflon tape on a fuel system. They have banned it from use on airplanes, even experimental aircraft for this VERY reason.
Old Jan 28, 2006 | 03:11 PM
T.B.'s Avatar
Could I Jb Weld The Bolt Back Together Or Would That Be Bad For The Fuil
Old Jan 28, 2006 | 03:12 PM
Shovelhead's Avatar
Administrator / Scooter Bum
(Hope you're not serious)
New bolt time.
The Cummins would shake it apart in no time.
Where are you?, your profile doesn't show a hometown.
Edit:
I see from a previous post you're in Ohio.
If you were closer, I'd let you have one of my old ones.
I swtched to the AN fittings with my Scotty Smart Fuel System so I have the stockers, and a set of the Drilled Banjos setting in my toolbox.
Old Jan 28, 2006 | 03:19 PM
T.B.'s Avatar
Just Kiddin Going To Order New Bolt. I Live In Mount Orab Ohio. Any One Now Of A Diesel Shop In The Area?
Old Jan 28, 2006 | 03:57 PM
Ph4tty's Avatar
http://www.dieselmanor.com/dm_products/DM-DBBLT.asp
http://www.genosgarage.com/CoastalDa...ID=593&CATID=1
Here's a couple places to get banjo bolts
Old Jan 28, 2006 | 06:00 PM
srt20's Avatar
sounds good, no teflon tape for me. thanks for the replies. Bret
Stamey
14
Dec 31, 2002 08:35 AM
Mr. 45
Dec 20, 2002 05:24 PM
14
Nov 20, 2002 11:06 AM
latitud_rt
Oct 23, 2002 08:19 AM
