Auto Trans ??
Old Oct 12, 2007 | 07:42 AM
vzdude's Avatar
DTR's 'Go to Guy'
Hook up all of your connections . Back probe the connector on the reference wire. It is probably backfeeding voltage on that wire because the sensor 5v feed has no where to go when the tps isn't hooked up. All sensors should be checked hooked up. You can check for the 5v and ground when unhooked, but when checking the reference wire, it should be in circuit.
Old Oct 25, 2007 | 07:52 AM
dragstriptrash's Avatar
overdrive switch
I was reading on a switch for od for my 1995 if i am right my od solenoid has three wires on it,orange black tracer a brown and a green w/ black tracer, which wire do i ground with a toggle switch to get od.please help fuel mileage
is terrible
Old Oct 25, 2007 | 09:06 AM
do I need to ground both of the outside wires
DodgeDiesel61
Jun 3, 2008 07:50 PM
lews930
Mar 7, 2007 06:33 PM
spitfire9137
Mar 10, 2006 06:29 AM
ezdemon72
14
Jul 29, 2005 10:05 AM
ckennedy
Sep 27, 2004 11:58 AM
