Auto Trans ??
Old Sep 17, 2007 | 07:50 PM
dragstriptrash's Avatar
Question Auto Trans ??
I have a 95 2500 auto OD, will not go into OD, I done the tps check, 5v input
ground was there But the signal wire had 4.93v, with the tps unplugged, Is that normal? Also when it makes the 2-3 shift under a light load it "slips into gear" But under harder accel. it shifts fine. PLEASE HELP
Old Sep 17, 2007 | 08:13 PM
badme's Avatar
Sounds like the od solenoid does not work. make sure the brake light switch is not sticking, lock up will not happen with the brake lights on. If not I would check the od solenoid next. A shift kit would do wonders for it, should cure your 2/3 shift. It will raise line preasure, firming up the shifts.
Old Sep 18, 2007 | 04:13 AM
ok thanks, but can anyone tell me if there should be voltage on the signal wire with the tps unplugged Thanks Again
Old Sep 18, 2007 | 04:27 AM
One more question, How can I tell which trans I have? I am new to the dodge
world Thanks again
Old Sep 19, 2007 | 08:19 PM
Any help would be great guys
THANKS Again
Old Sep 19, 2007 | 08:43 PM
badme's Avatar
world Thanks again
Should be a 47RH. If you can find a friendly parts department at a dealer have them run your vin # and print a line ticket. It will tell you every option on the truck. They are great, I have a friend that owns a Jeep dealership and I have him print one out for every chrysler product that I own.
Old Sep 21, 2007 | 06:44 PM
Can someone tell me what the voltage is supposed to be on the signal wire on the TPS with it unplugged and switch on, thanks mine has 4.93
volts Thanks
Old Sep 22, 2007 | 08:39 AM
brian55290's Avatar
if you unplug the harness from the tps there should only a 5 volt reference on 1 side and ground on the other side. the signal wire should not have any voltage when unplugged. when plugged in 5vt on ref ground on ground and about .5vt on signal wire.
Old Sep 22, 2007 | 05:21 PM
Dean Snow's Avatar
my speed sensor went bad and it wouldn't switch into overdrive, it still read fine on the speedo but wouldn't allow it into overdrive.
Old Sep 23, 2007 | 08:30 AM
Any ideas on why I am showing 4.93 volts on signal wire with sensor unplugged? Has anyone else had this problem? Any help on this would
be great Thanks
Old Sep 25, 2007 | 07:20 PM
Any ideas Guys
Old Oct 9, 2007 | 04:50 AM
ok had the tranny rebuilt, 3rd and od clutches were gone.but still no od or lock up.replaced the brake switch still nothing. I traced the signal wire to the pcm, cut it 1 in. from the pcm, had 4.95v at the pcm. Is the pcm shorted?
Old Oct 9, 2007 | 10:06 AM
patdaly's Avatar
I'm no expert by any means, but that would be my guess. You might also want to see if there is some form of mystery switch or potentiometer somewhere else causing this, though I am not sure where it would be. Do a search here under mystery switch and see what it brings up.
Old Oct 9, 2007 | 06:34 PM
patdaly's Avatar
Just for giggles, I looked at my 97 FSM, I don't know for sure of yours is the same, but on the 97, PCM connector C1, the TPS voltage feed goes in wire at A23, and conveniently there is fused 12V at A22. Perhaps some corrosion or something else is allowing voltage across A22 and A23 at the connector?
Best I can come up with right now.
Old Oct 12, 2007 | 04:13 AM
Unhappy
come on guys I need help here I dont have a clue wht to do now
Thanks
