anti freeze leak 1996 12 v
Old Feb 11, 2007 | 03:50 PM
hockey doc's Avatar
I cant figure it out it is on the passenger side 5 cylenders back under neath a round cylender which i do not know what that is but it is underneath it.
Old Feb 11, 2007 | 04:00 PM
hockey doc's Avatar
whoops spelt cylinder wrong
Old Feb 11, 2007 | 04:11 PM
torquefan's Avatar
The cylinder is the heat exchanger used to cool and warm your auto trans fluid. The leak may be from the heat exchanger itself, one of its connections, a frost plug behind it, or the head gasket directly above it. You may have to loosen its mounts and pull it away from the engine, without undoing its coolant connections (if possible) to see where the coolant is coming from.
Old Feb 11, 2007 | 08:40 PM
hockey doc's Avatar
ok i will try it tomorrow
Old Feb 11, 2007 | 09:05 PM
XLR8R's Avatar
I can't remember - was Dodge using the 53 blocks back in '96?
Old Feb 12, 2007 | 05:47 PM
hockey doc's Avatar
im not sure i just got the truck a few days ago there was no leak from when i bought it but when i got it home the next day it was leaking in the drive way im still learning alot about them im not sure.
Old Feb 12, 2007 | 05:48 PM
hockey doc's Avatar
when i turned it on the leak stoped and hasent leaked since know it is leaking towards the water pump
Old Feb 13, 2007 | 04:54 PM
TxDiesel007's Avatar
NOpe
I think those were 98 and up 12V.... I dont recall the 96 havin a frost plug either. I jsut did a twins install and was lookin for the darn thing. No avail..
Rick
Old Feb 13, 2007 | 07:42 PM
hockey doc's Avatar
the leak stopped i dont know what it is there was a little drip from around the water pump but that stopped also im not sure what it was maybe just the cold did something is that possible.
Old Feb 13, 2007 | 09:47 PM
RCW's Avatar
RCW
I would check the acidity of the antifreeze, and if it is slightly high then change it, flush the cooling system, and add a large bottle of BarsLeak at the same time. Use BarsLeak, and nothing else, as you want the soluble oil that is found only in that particular brand.
If you do not have a test kit for acidity, use a volt meter and insert one probe in the radiator so it only contacts the coolant, and then ground the other to the block. If you get any electrical readings at all, change the coolant.
Old coolant, or any of the orange crap that is over 6 months old, will develop an electrical charge that will cause very cold coolant to weep as it seeks a neutral electrical source.
Old Feb 14, 2007 | 08:30 AM
TIMMY22's Avatar
Old coolant can also "errode" cast iron engine parts. especially sleeves in wet sleeve applications. more reading here.
http://www.baldwinfilter.com/engineer/00_1.html
Old Mar 13, 2007 | 02:20 PM
hockey doc's Avatar
there is still a leak from the water pump from time to time
Old Mar 13, 2007 | 03:17 PM
berner's Avatar
Loose hose connections sometimes won't show up untill it's really cold outside. Have you checked them all?
dodgeman5902
Nov 15, 2013 06:08 AM
1_buck_truck
Nov 8, 2012 03:34 PM
Featherman
Nov 5, 2009 09:35 AM
bluebull
Nov 12, 2007 08:54 PM
Lyall
Sep 7, 2006 06:38 AM
