annoying grinding somewhere in front axle..help
mr T - with the links i gave you and if you are some what mechanicly inclined you should be able to do it your self , if you have never had one apart,and if truck hasn't been apart recently i would think you should be able to do it in 1/2 a day.you should not have to change the seal if it is not leaking, on the drivers side the seal is next to the diff..to change the seal the diff would have to come out.
here is another thread on the seal and leak https://www.dieseltruckresource.com/...threadid=65460
thanx POR i am in the process of doing everything...had to get the 1 11/16's driver ...im just trying to narrow things down as much as possible...plus askign alot of questions helps me learn much more
..so... where's the center support bearing that was mentioned?
it's on the pass. side in the axle diconect, here is a link with picture down the page.
http://dodgeram.org/tech/repair/4X4/...CAD_engagement
Dieseldude4x4
13
Jan 12, 2009 10:28 AM
shrmpboatcptn
Apr 20, 2008 08:46 PM
stirpicult
17
Feb 2, 2008 06:35 PM
cLAYH
Feb 6, 2004 10:59 AM
